Introdução
This replacement guide will show you how to disconnect the optical drive from your HP EliteBook 8570w. It consists of 4 relatively easy steps that should guide you successfully.
O que você precisa
Begin by removing the computers back covering.
Use the right slider to unlock the backing.
Slide the backing towards you while holding the slider to remove it.
Quase terminado!
Conclusão
