Ir para o conteúdo principal
HP Elitebook 8570w Optical Drive Replacement
O que você precisa
  1. HP Elitebook 8570w Optical Drive Replacement, Optical Drive: passo 1, imagem 1 %32
    • Begin by removing the computers back covering.
    • Use the right slider to unlock the backing.
    • Slide the backing towards you while holding the slider to remove it.
  2. HP Elitebook 8570w Optical Drive Replacement: passo 2, imagem 1 %32
    • Once the backing is removed, locate the panel to the left where the optical drive is stored.
    • Locate the single screw in the photo.
    • Unscrew the 0.8mm Phillips screw and place to the side.
  3. HP Elitebook 8570w Optical Drive Replacement: passo 3, imagem 1 %32
    • Locate the small metal piece in the photo.
    • Using a tool, push the piece in the given direction.
  4. HP Elitebook 8570w Optical Drive Replacement: passo 4, imagem 1 %32 HP Elitebook 8570w Optical Drive Replacement: passo 4, imagem 2 %32
    • Once pushing the piece outwards, the optical drive will pop out of the side of the computer.
    • Grab the optical drive and carefully remove it from the back of the computer.
Conclusão
MJ Routh
Membro desde: 11/06/17
465 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S8-G5, Johnson Fall 2017 Membro de Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 13
Duração total: 1,929
