Ir para o conteúdo principal
HP Elitebook 8570w Display Replacement
O que você precisa
  1. HP Elitebook 8570w Display Replacement, Display: passo 1, imagem 1 %32 HP Elitebook 8570w Display Replacement, Display: passo 1, imagem 2 %32 HP Elitebook 8570w Display Replacement, Display: passo 1, imagem 3 %32
    • With the computer opened, locate the square buttons on both bottom corners of the display.
    • Using a tool or finger, wedge the squares off revealing a screw on each corner.
  2. HP Elitebook 8570w Display Replacement: passo 2, imagem 1 %32
    • Use a T9 screwdriver to unscrew both 0.4mm Torx screws.
  3. HP Elitebook 8570w Display Replacement: passo 3, imagem 1 %32 HP Elitebook 8570w Display Replacement: passo 3, imagem 2 %32
    • Use an opening tool or spudger to peel back the outer rim of the display.
    • Continue to peel back the entire rim.
  4. HP Elitebook 8570w Display Replacement: passo 4, imagem 1 %32
    • Unscrew ONLY the bottom 0.8mm T9 Torx screw on both sides of the display.
  5. HP Elitebook 8570w Display Replacement: passo 5, imagem 1 %32 HP Elitebook 8570w Display Replacement: passo 5, imagem 2 %32 HP Elitebook 8570w Display Replacement: passo 5, imagem 3 %32
    • Now locate the two screws on each side at the bottom of the display.
    • TOP screw: unscrew partially.
    • BOTTOM screw: completely unscrew and set to the side.
    • Complete on both sides of display.
    • Carefully separate the display from the top cover.
    • Be sure to not let the top cover fall back
  6. HP Elitebook 8570w Display Replacement: passo 6, imagem 1 %32 HP Elitebook 8570w Display Replacement: passo 6, imagem 2 %32
    • Use a Phillips #00 screwdriver to unscrew all four 0.8 mm screws from the left side of the display frame. Repeat for the right side.
    • Push the metal plates/rods that were attached to the display towards the top cover.
    • The display should be completely free of the top cover and able to lay flat on the keyboard (refer to photo #2).
  7. HP Elitebook 8570w Display Replacement: passo 7, imagem 1 %32 HP Elitebook 8570w Display Replacement: passo 7, imagem 2 %32 HP Elitebook 8570w Display Replacement: passo 7, imagem 3 %32
    • With the display laying on the keyboard, locate the black square panel marked in the photo.
    • Grab the side marked in photo #2 and pull it towards you peeling off the surrounding tape and releasing it from the actual display board.
    • This will then remove the connection between the display and the top cover.
Conclusão
4 outras pessoas executaram este guia.
MJ Routh
Membro desde: 11/06/17
465 Reputação
Autoria de 3 guias
Equipe
Baylor, Team S8-G5, Johnson Fall 2017 Membro de Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
Membros da 3
Autoria de 4 guias
2 comentários
this guide is really bad, dangerous and should be removed !
at step 3 you crack and kill the existing display. If it was still somewhat working before now you are assured it is completely dead !
adrenochrome - Responder
agreed, step 3 should use the opening tool on a top corner of the bezel, not against the screen. you just screwed up the screen if it worked at all
Hidden Djinn - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 33
Duração total: 3,565
