Ir para o conteúdo principal
HP Elitebook 8460p Optical Drive Replacement
O que você precisa
  1. HP Elitebook 8460p Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Optical Drive Replacement: passo 2, imagem 1 %32
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Optical Drive Replacement, Back Panel: passo 3, imagem 1 %32
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Optical Drive Replacement: passo 4, imagem 1 %32
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: passo 5, imagem 1 %32 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: passo 5, imagem 2 %32 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: passo 5, imagem 3 %32
    • Using a Phillips #0 bit, unscrew the one Phillips head screw.
    • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
  6. HP Elitebook 8460p Optical Drive Replacement: passo 6, imagem 1 %32 HP Elitebook 8460p Optical Drive Replacement: passo 6, imagem 2 %32
    • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
  7. HP Elitebook 8460p Optical Drive Replacement: passo 7, imagem 1 %32 HP Elitebook 8460p Optical Drive Replacement: passo 7, imagem 2 %32 HP Elitebook 8460p Optical Drive Replacement: passo 7, imagem 3 %32
    • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
    • Using a small paper clip, push the paper clip straight in to open the optical drive.
  8. HP Elitebook 8460p Optical Drive Replacement: passo 8, imagem 1 %32 HP Elitebook 8460p Optical Drive Replacement: passo 8, imagem 2 %32 HP Elitebook 8460p Optical Drive Replacement: passo 8, imagem 3 %32
    • Using a small point, pop the tab out.
    • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,059
