Ir para o conteúdo principal
HP Elitebook 8460p Modem Card Replacement
O que você precisa
  1. HP Elitebook 8460p Modem Card Replacement, Battery: passo 1, imagem 1 %32
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Modem Card Replacement: passo 2, imagem 1 %32
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Modem Card Replacement, Back Panel: passo 3, imagem 1 %32
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Modem Card Replacement: passo 4, imagem 1 %32
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Modem Card Replacement, Modem Card: passo 5, imagem 1 %32 HP Elitebook 8460p Modem Card Replacement, Modem Card: passo 5, imagem 2 %32
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
  6. HP Elitebook 8460p Modem Card Replacement: passo 6, imagem 1 %32 HP Elitebook 8460p Modem Card Replacement: passo 6, imagem 2 %32
    • Push down on one corner of the sound card and lift it straight up.
  7. HP Elitebook 8460p Modem Card Replacement: passo 7, imagem 1 %32 HP Elitebook 8460p Modem Card Replacement: passo 7, imagem 2 %32
    • Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 24
Últimos 30 dias: 39
Duração total: 1,731
