Ir para o conteúdo principal
HP Elitebook 8460p Keyboard Replacement
O que você precisa
  1. HP Elitebook 8460p Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Keyboard Replacement, Back Panel: passo 3, imagem 1 %32
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Keyboard Replacement: passo 4, imagem 1 %32
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 HP Elitebook 8460p Keyboard Replacement, Keyboard: passo 5, imagem 2 %32 HP Elitebook 8460p Keyboard Replacement, Keyboard: passo 5, imagem 3 %32
    • Attach ESD strap around your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws in front of the battery slot located on the bottom of the laptop.
  6. HP Elitebook 8460p Keyboard Replacement: passo 6, imagem 1 %32
    • Flip the laptop over and open the screen.
  7. HP Elitebook 8460p Keyboard Replacement: passo 7, imagem 1 %32 HP Elitebook 8460p Keyboard Replacement: passo 7, imagem 2 %32 HP Elitebook 8460p Keyboard Replacement: passo 7, imagem 3 %32
    • Using a spudger, work around the edge of the keyboard and pry it up from the device.
  8. HP Elitebook 8460p Keyboard Replacement: passo 8, imagem 1 %32 HP Elitebook 8460p Keyboard Replacement: passo 8, imagem 2 %32
    • Lift the keyboard out of the laptop and flip it over.
    • This exposes two different connectors. Both need to be detached in order to remove the keyboard. The larger connector is the main keyboard cable.
  9. HP Elitebook 8460p Keyboard Replacement: passo 9, imagem 1 %32 HP Elitebook 8460p Keyboard Replacement: passo 9, imagem 2 %32
    • Disconnect the keyboard cable on the laptop using a thin pry tool to open the connection.
    • Open the connection by inserting a thin plastic pry tool under the black tab in the connector and flipping it up.
  10. HP Elitebook 8460p Keyboard Replacement: passo 10, imagem 1 %32 HP Elitebook 8460p Keyboard Replacement: passo 10, imagem 2 %32
    • Using the spudger again, disconnect the thin ribbon strip on the back of the keyboard.
Conclusão
3 outras pessoas executaram este guia.
2 comentários
There's a third keyboard screw right beside the fan
Colin Chaplin - Responder
yeah just wanted to say this ...
Also the screws are PH1 not PH0
Robert Kohari -
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 46
Ao todo: 4,155
