Ir para o conteúdo principal
HP Elitebook 8460p Hard Drive Replacement
O que você precisa
  1. HP Elitebook 8460p Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Hard Drive Replacement: passo 2, imagem 1 %32
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Hard Drive Replacement, Back Panel: passo 3, imagem 1 %32
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Hard Drive Replacement: passo 4, imagem 1 %32
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 HP Elitebook 8460p Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32
    • Attach an ESD strap to your wrist and to a ground.
    • Pull the tab with the small engraved arrow up and towards the inside of the laptop.
  6. HP Elitebook 8460p Hard Drive Replacement: passo 6, imagem 1 %32 HP Elitebook 8460p Hard Drive Replacement: passo 6, imagem 2 %32
    • Using a Phillips #0 bit, unscrew the three screws that hold the hard drive assembly in place.
  7. HP Elitebook 8460p Hard Drive Replacement: passo 7, imagem 1 %32 HP Elitebook 8460p Hard Drive Replacement: passo 7, imagem 2 %32
    • Remove the silver metal cover by pulling straight up on the black tab.
  8. HP Elitebook 8460p Hard Drive Replacement: passo 8, imagem 1 %32
    • Disconnect the hard drive by pulling the drive straight out to the left.
    • If replacing the hard drive, seat the new hard drive firmly in the connector.
Conclusão
10 outras pessoas executaram este guia.
4 comentários
Thanks! This made hard drive replacement on Elitebook VERY Easy!
Patrick Murphy - Responder
Awesome! So glad that it was able to help you out and keep your Elitebook running. Have a wonderful day!
Garrett Anderson -
Now it won't see the new HD to install to. W10 says the drive can't be used for booting and to enable it in BIOS.
Can't find where to enable it, however.
Rich Frueh - Responder
Meh. Took out battery, let sit for a while. Hit power a few times, plugged back in, and presto!
Not my favorite HP laptop.
Rich Frueh -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 45
Últimos 30 dias: 94
Duração total: 6,823
