Ir para o conteúdo principal
HP Elitebook 8460p Cooling Fan Replacement
O que você precisa
  1. HP Elitebook 8460p Cooling Fan Replacement, Battery: passo 1, imagem 1 %32
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Cooling Fan Replacement: passo 2, imagem 1 %32
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Cooling Fan Replacement, Back Panel: passo 3, imagem 1 %32
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Cooling Fan Replacement: passo 4, imagem 1 %32
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: passo 5, imagem 1 %32 HP Elitebook 8460p Cooling Fan Replacement, CPU Cooling Fan: passo 5, imagem 2 %32
    • Attach an ESD strap to your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws on opposite corners of the fan.
  6. HP Elitebook 8460p Cooling Fan Replacement: passo 6, imagem 1 %32 HP Elitebook 8460p Cooling Fan Replacement: passo 6, imagem 2 %32
    • Pull the fan straight up and to the side slightly.
  7. HP Elitebook 8460p Cooling Fan Replacement: passo 7, imagem 1 %32 HP Elitebook 8460p Cooling Fan Replacement: passo 7, imagem 2 %32
    • Disconnect the small electrical connector. Pry the edge up with your finger nails or using a small plastic pry tool.
  8. HP Elitebook 8460p Cooling Fan Replacement: passo 8, imagem 1 %32
    • Using a Phillips #0 bit, unscrew the six screws on the heat sink.
  9. HP Elitebook 8460p Cooling Fan Replacement: passo 9, imagem 1 %32 HP Elitebook 8460p Cooling Fan Replacement: passo 9, imagem 2 %32
    • Pry the inside edge up, pulling the entire assembly to the inside of the laptop, exposing the processor and graphics processor
    • Clean and replace the thermal paste on the processor if you have any thermal paste.
  10. HP Elitebook 8460p Cooling Fan Replacement: passo 10, imagem 1 %32
    • Blow compressed air through the vent from the outside and through the heat sink.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 33
Últimos 30 dias: 46
Duração total: 4,835
