Ir para o conteúdo principal
HP Elitebook 8460p Bluetooth Card Replacement
  1. HP Elitebook 8460p Bluetooth Card Replacement, Battery: passo 1, imagem 1 %32
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Bluetooth Card Replacement: passo 2, imagem 1 %32
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Bluetooth Card Replacement, Back Panel: passo 3, imagem 1 %32
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Bluetooth Card Replacement: passo 4, imagem 1 %32
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Bluetooth Card Replacement, Bluetooth Card: passo 5, imagem 1 %32 HP Elitebook 8460p Bluetooth Card Replacement, Bluetooth Card: passo 5, imagem 2 %32
    • Attach an ESD strap to your wrist and to a ground.
    • Using a fingernail, grasp the small connector and separate the connector from the Bluetooth card.
  6. HP Elitebook 8460p Bluetooth Card Replacement: passo 6, imagem 1 %32
    • Grasp the Bluetooth card and pull it straight out to the left.
Conclusão
7 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 70
Ao todo: 5,609
