Ir para o conteúdo principal
HP Elitebook 820 G1 RAM Replacement
O que você precisa
  1. HP Elitebook 820 G1 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 RAM Replacement: passo 2, imagem 1 %32
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 RAM Replacement: passo 3, imagem 1 %32
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 RAM Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 RAM Replacement, RAM: passo 5, imagem 1 %32
    • Once the battery is removed from the device, slide both latches away from the RAM module with your fingers.
    • The latches are spring assisted and the RAM module will lift for removal.
Conclusão
Equipe
USF Tampa, Team S5-G1, Eyestone Spring 2018 Membro de USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 1,191
