Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn over laptop so that the bottom is showing.
Unlock the latch.
Remove the back cover and you will then be able to see the battery.
Unlatch the two latches securing the battery in the case.
Use a plastic opening tool to lift and remove the battery.
Remove the hard drive by unscrewing the four 8mm screws with the T7 philip's head.
Pry off ten rubber paddings on the outer edge of the laptop to reveal the torx screws.
Unscrew the ten 8mm torx screws that are under the rubber paddings using the T7 tip torx screwdriver.
Remove the two 4mm screws indicated by the M2.5X4 using the J00 tip screwdriver.
Remove SD card cap by just sliding out to reveal one screw.
Remove the two 3mm screws indicated by the M2.03 using the J00 tip screwdriver.
Remove the 4mm SD card screw using the J00 tip.
Remove the one 4mm fan screw using the J00 tip screwdriver.
Remove screw and metal plate to expose ribbon cable connector.
Use an opening tool to pry up the ribbon connector to disconnect.
Turn laptop over back to normal position as shown in the image.
Use opening tools to pry up keyboard.
Carefully lift keyboard on one side to expose the two ribbon cables.
Use an opening tool to lift up the locking clip and unplug the two ribbon cables.
Remove the two 4mm screws centered notated by the keyboard logo using the J00 tip.
Once keyboard has been fully removed, the system case containing the motherboard can be lifted out easily.
The display is connected to the shell of the laptop.
Unplug fan cable by pulling away from its connector.
Retrieve the monitor display connected to the plastic chassis.
Unscrew the two 4mm hinge screws using the Philips 00 tip screwdriver.
