Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Turn over laptop so that the bottom is showing.
Unlock the latch.
Remove the back cover and you will then be able to see the battery.
Unlatch the two latches securing the battery in the case.
Use a plastic opening tool to lift and remove the battery.
Remove the two Phillips #0 screws securing the keyboard to the laptop.
Turn the laptop over and lift the display to reveal the keyboard.
Insert the plastic spudger between the keyboard and the housing.
4 tabs are located at the top of the keyboard, which lock it in place.
Pry and twist the spudger along the top of the keyboard until each tab is released.
Flip up the connecting flap on each of the three ribbon cables.
Remove each of the three cables by gently pulling them from their respective connectors.
4 outras pessoas executaram este guia.
Um comentário
Good guide. Thanks!
But you missed step 1. Remove two screws that hold the keyboard in place
