Ir para o conteúdo principal
HP Elitebook 820 G1 Keyboard Replacement
O que você precisa
  1. HP Elitebook 820 G1 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Keyboard Replacement: passo 3, imagem 1 %32
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Keyboard Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32
    • Remove the two Phillips #0 screws securing the keyboard to the laptop.
    • Turn the laptop over and lift the display to reveal the keyboard.
  6. HP Elitebook 820 G1 Keyboard Replacement: passo 6, imagem 1 %32
    • Insert the plastic spudger between the keyboard and the housing.
    • Start at the corner.
    Bei mir ging es am Besten mit einem dünnen Plektrum. Außerdem war es am oberen Rand so eng, dass ich überhaupt nicht dazwischen kam. An der oberen rechten Ecke seitlich ging es dann gut.
    Johannes Lang - Responder
  7. HP Elitebook 820 G1 Keyboard Replacement: passo 7, imagem 1 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 7, imagem 2 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 7, imagem 3 %32
    • 4 tabs are located at the top of the keyboard, which lock it in place.
    • Pry and twist the spudger along the top of the keyboard until each tab is released.
  8. HP Elitebook 820 G1 Keyboard Replacement: passo 8, imagem 1 %32
    • Pull back the keyboard from the top.
    • Be mindful of the fragile cables behind it.
  9. HP Elitebook 820 G1 Keyboard Replacement: passo 9, imagem 1 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 9, imagem 2 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 9, imagem 3 %32
    • Flip up the connecting flap on each of the three ribbon cables.
    • The small cable on the last picture ist only there, if you have a backlit keyboard. If you want to replace a keyboard without backlight, there will be no cable on your original keyboard.
    This is all very helpful, thank you.
    Just a query. When I took my keyboard off I appeared to have only two ribbons in the existing keyboard, the broadest one and the one of the back light (towards the middle) that didn’t work. The third right next to the broadest ribbon was absent altogether. Why? What was it for? Thanks
    Tim Sunderland - Responder
  10. HP Elitebook 820 G1 Keyboard Replacement: passo 10, imagem 1 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 10, imagem 2 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 10, imagem 3 %32
    • Remove each of the three cables by gently pulling them from their respective connectors.
  11. HP Elitebook 820 G1 Keyboard Replacement: passo 11, imagem 1 %32
    • Remove the keyboard from the housing.
Conclusão
4 outras pessoas executaram este guia.
Lauren Vance
Membro desde: 10/31/18
388 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G2, Harley Fall 2018 Membro de IUPUI, Team S1-G2, Harley Fall 2018
IUPUI-HARLEY-F18S1G2
Membros da 2
Autoria de 4 guias
Um comentário
Good guide. Thanks!
But you missed step 1. Remove two screws that hold the keyboard in place
Chris Maschmeier - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 42
Duração total: 11,021
