Ir para o conteúdo principal
HP Elitebook 820 G1 Keyboard Replacement
O que você precisa
  1. HP Elitebook 820 G1 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Keyboard Replacement: passo 2, imagem 1 %32
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Keyboard Replacement: passo 3, imagem 1 %32
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Keyboard Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32
    • Remove the two Phillips #0 screws securing the keyboard to the laptop.
    • Turn the laptop over and lift the display to reveal the keyboard.
  6. HP Elitebook 820 G1 Keyboard Replacement: passo 6, imagem 1 %32
    • Insert the plastic spudger between the keyboard and the housing.
    • Start at the corner.
  7. HP Elitebook 820 G1 Keyboard Replacement: passo 7, imagem 1 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 7, imagem 2 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 7, imagem 3 %32
    • 4 tabs are located at the top of the keyboard, which lock it in place.
    • Pry and twist the spudger along the top of the keyboard until each tab is released.
  8. HP Elitebook 820 G1 Keyboard Replacement: passo 8, imagem 1 %32
    • Pull back the keyboard from the top.
    • Be mindful of the fragile cables behind it.
  9. HP Elitebook 820 G1 Keyboard Replacement: passo 9, imagem 1 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 9, imagem 2 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 9, imagem 3 %32
    • Flip up the connecting flap on each of the three ribbon cables.
    • The small cable on the last picture ist only there, if you have a backlit keyboard. If you want to replace a keyboard without backlight, there will be no cable on your original keyboard.
  10. HP Elitebook 820 G1 Keyboard Replacement: passo 10, imagem 1 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 10, imagem 2 %32 HP Elitebook 820 G1 Keyboard Replacement: passo 10, imagem 3 %32
    • Remove each of the three cables by gently pulling them from their respective connectors.
  11. HP Elitebook 820 G1 Keyboard Replacement: passo 11, imagem 1 %32
    • Remove the keyboard from the housing.
Conclusão
4 outras pessoas executaram este guia.
Lauren Vance
Membro desde: 10/31/18
388 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G2, Harley Fall 2018 Membro de IUPUI, Team S1-G2, Harley Fall 2018
IUPUI-HARLEY-F18S1G2
Membros da 2
Autoria de 4 guias
Um comentário
Good guide. Thanks!
But you missed step 1. Remove two screws that hold the keyboard in place
Chris Maschmeier - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 39
Duração total: 11,175
