Ir para o conteúdo principal
HP Elitebook 820 G1 Hard Drive Replacement
O que você precisa
  1. HP Elitebook 820 G1 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
    • Turn over laptop so that the bottom is showing.
    • Unlock the latch.
  2. HP Elitebook 820 G1 Hard Drive Replacement: passo 2, imagem 1 %32
    • Remove the back cover and you will then be able to see the battery.
  3. HP Elitebook 820 G1 Hard Drive Replacement: passo 3, imagem 1 %32
    • Unlatch the two latches securing the battery in the case.
  4. HP Elitebook 820 G1 Hard Drive Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to lift and remove the battery.
  5. HP Elitebook 820 G1 Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32
    • Remove the four 8mm screws with the T7 philip's head.
  6. HP Elitebook 820 G1 Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove the hard drive casing.
    • Unscrew the four 8mm Philips screws holding the hard drive.
  7. HP Elitebook 820 G1 Hard Drive Replacement: passo 7, imagem 1 %32
    • Remove the hard drive from the casing and replace it.
Conclusão
3 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S5-G1, Eyestone Spring 2018 Membro de USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 3,761
