Ir para o conteúdo principal
HP Elitebook 6930p RAM (Expansion Slot) Replacement
O que você precisa
  1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: passo 1, imagem 1 %32 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: passo 1, imagem 2 %32 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: passo 1, imagem 3 %32
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): passo 2, imagem 1 %32 HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): passo 2, imagem 2 %32
    • Locate the RAM expansion slot cover on the bottom of the laptop
    • Loosen the PM2.0×5.0 captive screw and remove the cover.
  3. HP Elitebook 6930p RAM (Expansion Slot) Replacement: passo 3, imagem 1 %32 HP Elitebook 6930p RAM (Expansion Slot) Replacement: passo 3, imagem 2 %32
    • Install RAM module into the RAM slot on an angle of around 30 degrees
    • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Check to ensure the metal tabs are holding the RAM module down on both sides
    • Reinstall the RAM cover
Conclusão
8 outras pessoas executaram este guia.
Richdave
Membro desde: 04/09/10
32.063 Reputação
Autoria de 30 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.532 guias
17 comentários
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - Responder
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - Responder
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Brian Fenech - Responder
Thank you for information.
By p8slot.com
sutep Fifa - Responder
Thanks for such amazing stuff. Please keep sharing.
<a href="https://168slotxo.net/the-secert-slot-on...>ความลับของสล็อตออนไลน์ในคาสิโน</a>
Shoaib - Responder
Thanks for such an amazing stuff. Please keep sharing.
<a href="https://168slotxo.net/168slotxo-the-best...>สล็อตออนไลน์</a>
Shoaib - Responder
You always share so amazing articles. I really love it.
slotxo
Shoaib - Responder
You always share so amazing articles. I love it.
slotxo
Shoaib - Responder
I am a big fan of your site and content.
pg
Shoaib - Responder
I am a big fan of your site and amazing content.
pgslot
Shoaib - Responder
Your content is always awesome.
pg
Shoaib - Responder
Your site is awesome. I will recommend this to everyone.
pg slot
Shoaib - Responder
Thanks for this information, please can i add 8gb to my expansion slot and leave the other 2gb that is under the keyboard?
Emeba Okeoghene - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 35
Duração total: 15,520
