Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
There are 2 RAM slots in the 6930p Laptop. One is the expansion slot and accessible from the underside of the device, the other is the default location for factory installed RAM and is located under the keyboard. This guide focuses on the expansion slot
Peças
Nenhum componente especificado.
  1. Flip laptop over and locate the battery release button Push release button to the left to release battery and gently pull battery from the laptop Push release button to the left to release battery and gently pull battery from the laptop
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Kit de ferramentas básico para eletrônica
    Kit pequeno. Grandes possibilidades.
    Shop Toolkits
    Kit de ferramentas
    básico para
    eletrônica
    Shop Toolkits
  3. Locate the RAM expansion slot cover on the bottom of the laptop Loosen the PM2.0×5.0 captive screw and remove the cover.
    • Locate the RAM expansion slot cover on the bottom of the laptop
    • Loosen the PM2.0×5.0 captive screw and remove the cover.
  4. Install RAM module into the RAM slot on an angle of around 30 degrees Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Install RAM module into the RAM slot on an angle of around 30 degrees
    • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
    • Check to ensure the metal tabs are holding the RAM module down on both sides
    • Reinstall the RAM cover
Conclusão
8 outras pessoas concluíram este guia.
Richdave
Membro desde: 09-04-2010
30.182 Reputação
30 Guias de autoria
Equipe
Master Techs Membro de Master Techs
Community
293 Membros
928 Guias de autoria
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - Responder
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Jan Cerenohorsky -
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - Responder
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Brian Fenech - Responder
Thank you for information.
By p8slot.com
sutep Fifa - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 54
Duração total: 12,520
