Ir para o conteúdo principal
HP Elitebook 6930p CPU Replacement
O que você precisa
  1. HP Elitebook 6930p CPU Replacement, Take off the Heatsink: passo 1, imagem 1 %32
    • Unscrew the screws in order from left to right in the picture.
    • Insert wisdom here.
  2. HP Elitebook 6930p CPU Replacement, Unplug the fan: passo 3, imagem 1 %32
    • Do this step if the cord of the fan is in the way of the CPU.
    • Make sure the new CPU works or is better than the old one if you are upgrading the CPU.
Conclusão
To reassemble your device, follow steps 1-4 in reverse order.
Uma outra pessoa concluiu este guia.
Lowell
Membro desde: 04/16/16
156 Reputação
Autoria de 2 guias
Um comentário
I have try to install both types T9900 and T9800 both CPU’s were not working at all. Bios F20 and operating System Win 7 32Bit.
it crashes already by try to access the bios
Maybe any sugestion about that?
moonlights - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 18
Duração total: 3,744
