Introdução
The computers hard drive is where all of its data is stored and kept when the computer is turned off. Upgrading it to a larger or faster HDD or SSD is very important in keeping your computer running properly. This simple guide shows how to easily access the HDD bay within the laptop.
O que você precisa
Place the laptop face down in front of you.
Use a Phillips #0 screwdriver to remove the three 3 mm screws from the back of the case.
Remove the back panel.
5 outras pessoas executaram este guia.
Um comentário
You can use any mSATA SSD as replacement by using the following caddy/adapter:
https://www.ebay.fr/itm/165266235415
jacques_06
