Ir para o conteúdo principal
HP EliteOne 800 G1 Power Supply Replacement
O que você precisa
  1. HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: passo 1, imagem 1 %32 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: passo 1, imagem 2 %32 HP EliteOne 800 G1 Power Supply Replacement, Removing the Back Cover: passo 1, imagem 3 %32
    • Place computer with the screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: passo 2, imagem 1 %32 HP EliteOne 800 G1 Power Supply Replacement, Removing Stand: passo 2, imagem 2 %32
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
  3. HP EliteOne 800 G1 Power Supply Replacement: passo 3, imagem 1 %32 HP EliteOne 800 G1 Power Supply Replacement: passo 3, imagem 2 %32
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
  4. HP EliteOne 800 G1 Power Supply Replacement: passo 4, imagem 1 %32 HP EliteOne 800 G1 Power Supply Replacement: passo 4, imagem 2 %32
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
  5. HP EliteOne 800 G1 Power Supply Replacement, Power Supply: passo 5, imagem 1 %32 HP EliteOne 800 G1 Power Supply Replacement, Power Supply: passo 5, imagem 2 %32
    • Use a Torx T15 driver to remove the four 10mm screws on the VESA mount cover.
    • Lift up on the VESA mount cover to remove it.
  6. HP EliteOne 800 G1 Power Supply Replacement: passo 6, imagem 1 %32
    • Disconnect the power supply's black and yellow cable from the motherboard.
  7. HP EliteOne 800 G1 Power Supply Replacement: passo 7, imagem 1 %32 HP EliteOne 800 G1 Power Supply Replacement: passo 7, imagem 2 %32
    • Use a Torx T15 driver to remove the two 8mm screws on either side of the power supply.
    • Lift the power supply from the case to remove it.
Conclusão
6 outras pessoas executaram este guia.
Michael Ewing
Membro desde: 10/01/15
1.071 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-24, Maness Fall 2015 Membro de Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 53
Duração total: 5,305
