Ir para o conteúdo principal
HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement
O que você precisa
  1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: passo 1, imagem 1 %32 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: passo 1, imagem 2 %32 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: passo 1, imagem 3 %32
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: passo 2, imagem 1 %32 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: passo 2, imagem 2 %32 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: passo 2, imagem 3 %32
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: passo 3, imagem 1 %32 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: passo 3, imagem 2 %32
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
Conclusão
4 outras pessoas executaram este guia.
Kyle Koivuniemi
Membro desde: 10/01/15
605 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-24, Maness Fall 2015 Membro de Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
Membros da 4
Autoria de 14 guias
2 comentários
where can i buy a replace cage for the hard drive?
Thomas Dickson - Responder
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 23
Últimos 30 dias: 71
Duração total: 8,392
