Ir para o conteúdo principal
HP EliteBook x360 830 G7 RAM Replacement
O que você precisa
  1. HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: passo 1, imagem 1 %32 HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: passo 1, imagem 2 %32
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: passo 2, imagem 1 %32 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: passo 2, imagem 2 %32 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: passo 2, imagem 3 %32
    • Gently lift the larger, rectangular metal shielding off. This shielding covers the RAM.
  3. HP EliteBook x360 830 G7 RAM Replacement, Remove the RAM: passo 3, imagem 1 %32
    • Push down on the two latches on both sides of the RAM to release it.
    • This will allow you to remove the RAM and replace it with no issues.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 72
Duração total: 1,068
