Ir para o conteúdo principal
HP EliteBook x360 830 G7 Display Replacement
O que você precisa
  1. HP EliteBook x360 830 G7 Display Replacement, Remove the display: passo 1, imagem 1 %32 HP EliteBook x360 830 G7 Display Replacement, Remove the display: passo 1, imagem 2 %32 HP EliteBook x360 830 G7 Display Replacement, Remove the display: passo 1, imagem 3 %32
    • Use an opening tool to remove the display from the laptop case. Place it in the area that you see the most give.
    • If you hear the plastic tabs "snapping" free, you should be fine.
    • Be careful not to crack the display.
  2. HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: passo 2, imagem 1 %32 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: passo 2, imagem 2 %32 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: passo 2, imagem 3 %32
    • With the screen removed, locate the pair of wires hidden underneath the two pieces of tape.
  3. HP EliteBook x360 830 G7 Display Replacement, Connector bracket: passo 3, imagem 1 %32 HP EliteBook x360 830 G7 Display Replacement, Connector bracket: passo 3, imagem 2 %32
    • Use a plastic opening tool or nylon spudger to lift the metal digitizer-connector bracket.
  4. HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: passo 4, imagem 1 %32 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: passo 4, imagem 2 %32 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: passo 4, imagem 3 %32
    • Now that the bracket is removed, pull the golden connector away from the silver base.
    • Now, the back of the display should look like this.
  5. HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: passo 5, imagem 1 %32 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: passo 5, imagem 2 %32 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: passo 5, imagem 3 %32
    • The next piece of tape that needs to be peeled, but not removed, is highlighted by the red rectangle.
    • Peel but do not remove the black piece of tape.
  6. HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: passo 6, imagem 1 %32 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: passo 6, imagem 2 %32 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: passo 6, imagem 3 %32
    • Peel, but do not remove entirely, the clear piece of tape that was underneath the black tape.
  7. HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: passo 7, imagem 1 %32 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: passo 7, imagem 2 %32 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: passo 7, imagem 3 %32
    • Pull the small, bronze "Brighton" ribbon cable connector from the tan connection base.
  8. HP EliteBook x360 830 G7 Display Replacement, Separate the display housing from the computer: passo 8, imagem 1 %32
    • If you can move your display's housing away from the computer, then you have successfully detached your display and can replace it.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 64
Duração total: 1,260
