Ir para o conteúdo principal
HP EliteBook x360 830 G5 M2 Solid State Drive Replacement
O que você precisa
  1. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, Back Cover: passo 1, imagem 1 %32
    • With the T5 screw-bit and screwdriver, loosen the five captive screws on the bottom of the laptop.
  2. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: passo 2, imagem 1 %32 HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: passo 2, imagem 2 %32
    • With a spudger or opening tool, pry above the computer's hinges and separate the posterior edge and sides.
  3. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: passo 3, imagem 1 %32
    • The back cover is held in place by magnetic strips.
    • Remove the battery.
  4. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement, M.2 Solid State Drive: passo 4, imagem 1 %32
    • Pull the tab attached to the M.2 solid state drive shield up.
  5. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: passo 5, imagem 1 %32
    • With the Phillips #1 screwdriver, loosen the single screw that secures the M.2 solid state drive to the system board.
  6. HP EliteBook x360 830 G5 M2 Solid State Drive Replacement: passo 6, imagem 1 %32
    • Once the springs release, carefully remove the M.2 solid state drive.
    • Pull the SSD card gently so you don't bend any pins.
Conclusão
Ashia Lewis
Membro desde: 09/03/21
246 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 551
