Introdução
This guide is for HP EliteBook x360 1030 G3. Before you replace the speakers, try to troubleshoot the problem first. Since the speakers are directly linked to the motherboard, so you may need to update your driver and may fix the speakers. If you think troubleshooting is not working, follow this guide to replace the speakers.
O que você precisa
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
Remove the six 1.95 mm JIS #000 screws that secure the metal frame of the touchpad.
