Ir para o conteúdo principal
HP EliteBook x360 1030 G3 Solid State Drive Replacement
O que você precisa
  1. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Solid State Drive Replacement: passo 2, imagem 1 %32
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: passo 3, imagem 1 %32 HP EliteBook x360 1030 G3 Solid State Drive Replacement, Solid State Drive: passo 3, imagem 2 %32
    • Lift the black tape covering the solid state drive.
  4. HP EliteBook x360 1030 G3 Solid State Drive Replacement: passo 4, imagem 1 %32
    • Remove the 2.4 mm screw using a Phillips #00 screwdriver.
  5. HP EliteBook x360 1030 G3 Solid State Drive Replacement: passo 5, imagem 1 %32
    • Slide the solid state drive to the left and out of its port.
    • Be careful when removing the solid state drive as bending any of the pins may render it unusable.
Conclusão
3 outras pessoas executaram este guia.
Pablo Arriola
Membro desde: 04/22/19
504 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S2-G9, Maness Spring 2019 Membro de Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
Membros da 4
Autoria de 16 guias
3 comentários
Which SSD is compatible with this computer?
Trinayaan Hariharan - Responder
Very nice its clear
Fuad Gugsa - Responder
J'ai un problème de son
Sallpape - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 28
Últimos 30 dias: 126
Duração total: 5,909
