Ir para o conteúdo principal
HP EliteBook x360 1030 G3 Fan Replacement
O que você precisa
  1. HP EliteBook x360 1030 G3 Fan Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Fan Replacement: passo 2, imagem 1 %32
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Fan Replacement, Fan: passo 3, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws near the middle of the fan assembly.
    • Use the same screwdriver to remove the remaining five 3.9 mm screws.
  4. HP EliteBook x360 1030 G3 Fan Replacement: passo 4, imagem 1 %32 HP EliteBook x360 1030 G3 Fan Replacement: passo 4, imagem 2 %32 HP EliteBook x360 1030 G3 Fan Replacement: passo 4, imagem 3 %32
    • Before pulling the fan out, identify the two wires that are connected to the fan and to the motherboard.
    • For each, use plastic opening tool to lift the black wire housing upward out of its port.
    • Be sure not to pull the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Fan Replacement: passo 5, imagem 1 %32 HP EliteBook x360 1030 G3 Fan Replacement: passo 5, imagem 2 %32
    • Slide the fan assembly toward you, and when the top edge of the fan is out of the vent grill, the fan is completely removed.
Conclusão
4 outras pessoas executaram este guia.
Pablo Arriola
Membro desde: 04/22/19
528 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S2-G9, Maness Spring 2019 Membro de Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
4 Membros
Autoria de 16 guias
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 99
Ao todo: 4,861
