Ir para o conteúdo principal
HP EliteBook x360 1030 G3 Bottom Cover Replacement
O que você precisa
  1. HP EliteBook x360 1030 G3 Bottom Cover Replacement, Bottom Cover: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Bottom Cover Replacement: passo 2, imagem 1 %32
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
Conclusão
Shea Charkowsky
Membro desde: 04/15/19
786 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S2-G9, Maness Spring 2019 Membro de Cal Poly, Team S2-G9, Maness Spring 2019
CPSU-MANESS-S19S2G9
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 23
Últimos 30 dias: 116
Duração total: 5,667
