Ir para o conteúdo principal
HP EliteBook 8560w Back Panel Replacement
O que você precisa
  1. HP EliteBook 8560w Back Panel Replacement, Battery: passo 1, imagem 1 %32 HP EliteBook 8560w Back Panel Replacement, Battery: passo 1, imagem 2 %32
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Back Panel Replacement: passo 2, imagem 1 %32
    • Pull the battery out.
  3. HP EliteBook 8560w Back Panel Replacement, Back Panel: passo 3, imagem 1 %32 HP EliteBook 8560w Back Panel Replacement, Back Panel: passo 3, imagem 2 %32
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Back Panel Replacement: passo 4, imagem 1 %32
    • Slide the panel towards you and lift it up to open and access the back of the computer.
Linha de Chegada
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 33
Ao todo: 1,639
