Ir para o conteúdo principal
HP EliteBook 8530w Battery Replacement
  1. HP EliteBook 8530w Battery Replacement, Battery: passo 1, imagem 1 %32 HP EliteBook 8530w Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Battery Replacement: passo 2, imagem 1 %32 HP EliteBook 8530w Battery Replacement: passo 2, imagem 2 %32
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 480
