Ir para o conteúdo principal
HP EliteBook 850 G3 Display Assembly Replacement
O que você precisa
  1. HP EliteBook 850 G3 Display Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Display Assembly Replacement, Unscrew the bottom: passo 2, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement, Unscrew the bottom: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Display Assembly Replacement: passo 3, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Display Assembly Replacement, Remove the battery screws: passo 4, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement, Remove the battery screws: passo 4, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Display Assembly Replacement, Lift the battery: passo 5, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement, Lift the battery: passo 5, imagem 2 %32 HP EliteBook 850 G3 Display Assembly Replacement, Lift the battery: passo 5, imagem 3 %32
    • Lift and pull the flap located at the top of the battery to remove it.
  6. HP EliteBook 850 G3 Display Assembly Replacement, WiFi Card: passo 6, imagem 1 %32
    • Flip the laptop over so the model stickers face the ceiling.
  7. HP EliteBook 850 G3 Display Assembly Replacement: passo 7, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 7, imagem 2 %32
  8. HP EliteBook 850 G3 Display Assembly Replacement: passo 8, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 8, imagem 2 %32
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  9. HP EliteBook 850 G3 Display Assembly Replacement: passo 9, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  10. HP EliteBook 850 G3 Display Assembly Replacement: passo 10, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 10, imagem 2 %32
    • Slide out the WiFi card.
  11. HP EliteBook 850 G3 Display Assembly Replacement: passo 11, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 11, imagem 2 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 11, imagem 3 %32
    • Disconnect the coaxial cables wires from the WiFi card.
  12. HP EliteBook 850 G3 Display Assembly Replacement, Fan: passo 12, imagem 1 %32
    • Gently unclip the plastic frame.
  13. HP EliteBook 850 G3 Display Assembly Replacement: passo 13, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 13, imagem 2 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 13, imagem 3 %32
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  14. HP EliteBook 850 G3 Display Assembly Replacement: passo 14, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 14, imagem 2 %32
    • Carefully remove the connector for the fan.
  15. HP EliteBook 850 G3 Display Assembly Replacement: passo 15, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 15, imagem 2 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 15, imagem 3 %32
    • Carefully remove the fan and heatsink assembly from the laptop.
  16. HP EliteBook 850 G3 Display Assembly Replacement, Display Assembly: passo 16, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement, Display Assembly: passo 16, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the 7.7mm screw and six 5.8 mm screws from the corners inside the laptop.
  17. HP EliteBook 850 G3 Display Assembly Replacement: passo 17, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the 5.7 mm screw under the plastic frame.
  18. HP EliteBook 850 G3 Display Assembly Replacement: passo 18, imagem 1 %32
    • Use the opening pick to unplug the cable with the black tab on top.
  19. HP EliteBook 850 G3 Display Assembly Replacement: passo 19, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 19, imagem 2 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 19, imagem 3 %32
    • Disconnect wire over gold tape and remove tape. You will have to peel the wire up to get to the tape.
    • The tape is not reusable.
  20. HP EliteBook 850 G3 Display Assembly Replacement: passo 20, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 20, imagem 2 %32
    • Remove the coaxial cables from the wifi card and from clear plastic holds. Remove the black tape and slip out from black clip.
    • This tape is not reusable.
  21. HP EliteBook 850 G3 Display Assembly Replacement: passo 21, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 21, imagem 2 %32
    • Open the top of the laptop and bend the hinges so that the metal bits in the corners will come up.
  22. HP EliteBook 850 G3 Display Assembly Replacement: passo 22, imagem 1 %32 HP EliteBook 850 G3 Display Assembly Replacement: passo 22, imagem 2 %32
    • Take the display assembly off.
Conclusão
Uma outra pessoa concluiu este guia.
Annabeth Grover
Membro desde: 10/10/19
922 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G1, Leahy Fall 2019 Membro de USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
Membros da 4
Autoria de 6 guias
3 comentários
looks like there are duplicate steps for cover removal.
Cody White - Responder
do tou have tuchscreen assenbly for same nmodel ??
shiva netra - Responder
do upu have couch scfeen assembly for this model ; hp elitebook 450g3
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 32
Duração total: 2,592
