Ir para o conteúdo principal
HP EliteBook 8470p Keyboard Replacement
O que você precisa
  1. HP EliteBook 8470p Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
  2. HP EliteBook 8470p Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
  3. HP EliteBook 8470p Keyboard Replacement: passo 3, imagem 1 %32
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
  4. HP EliteBook 8470p Keyboard Replacement, Case/Service Cover: passo 4, imagem 1 %32
    • With the laptop latch still facing away from you, slide the left release latch to the left.
    • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
  5. HP EliteBook 8470p Keyboard Replacement: passo 5, imagem 1 %32 HP EliteBook 8470p Keyboard Replacement: passo 5, imagem 2 %32
    • Slide the door away from you, toward the opening latch.
    • Lift the door upwards away from the computer.
  6. HP EliteBook 8470p Keyboard Replacement, Keyboard: passo 6, imagem 1 %32 HP EliteBook 8470p Keyboard Replacement, Keyboard: passo 6, imagem 2 %32 HP EliteBook 8470p Keyboard Replacement, Keyboard: passo 6, imagem 3 %32
    • Loosen the three captive Phillips screws securing the keyboard to the computer with a Phillips #00 screwdriver.
    • These are all positioned just above the middle of the laptop.
  7. HP EliteBook 8470p Keyboard Replacement: passo 7, imagem 1 %32
    • Rest the computer on its right edge carefully so that you can open the laptop.
    • Open the laptop.
  8. HP EliteBook 8470p Keyboard Replacement: passo 8, imagem 1 %32 HP EliteBook 8470p Keyboard Replacement: passo 8, imagem 2 %32
    • Insert a spudger or another small tool into the slot in the battery bay to release the keyboard.
    • Push firmly to disengage.
  9. HP EliteBook 8470p Keyboard Replacement: passo 9, imagem 1 %32
    • Open the computer towards you as if you were going to use it.
  10. HP EliteBook 8470p Keyboard Replacement: passo 10, imagem 1 %32
    • Lift the rear edge of the laptop.
    • Flip the far edge over and position the keyboard upside down on top of the touchpad.
  11. HP EliteBook 8470p Keyboard Replacement: passo 11, imagem 1 %32 HP EliteBook 8470p Keyboard Replacement: passo 11, imagem 2 %32
    • Release the connector in the middle of the back of the keyboard.
    • Disconnect the pointing stick.
  12. HP EliteBook 8470p Keyboard Replacement: passo 12, imagem 1 %32
    • Release the connector for the keyboard cable.
    • Remove the cable from the system.
  13. HP EliteBook 8470p Keyboard Replacement: passo 13, imagem 1 %32
    • Remove the keyboard.
Conclusão
Uma outra pessoa concluiu este guia.
Owen Bangs
Membro desde: 10/25/22
656 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 5-3, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G3
Membros da 5
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 47
Duração total: 844
