Ir para o conteúdo principal
HP EliteBook 845 G8 Thermal Paste Replacement
O que você precisa
  1. HP EliteBook 845 G8 Thermal Paste Replacement, Opening the back panel.: passo 1, imagem 1 %32 HP EliteBook 845 G8 Thermal Paste Replacement, Opening the back panel.: passo 1, imagem 2 %32 HP EliteBook 845 G8 Thermal Paste Replacement, Opening the back panel.: passo 1, imagem 3 %32
    • Remove the 5 screws holding the back panel.
    • Use a prying tool to carefully release all the clips holding the panel in place.
  2. HP EliteBook 845 G8 Thermal Paste Replacement, Removing the old thermal paste.: passo 2, imagem 1 %32 HP EliteBook 845 G8 Thermal Paste Replacement, Removing the old thermal paste.: passo 2, imagem 2 %32 HP EliteBook 845 G8 Thermal Paste Replacement, Removing the old thermal paste.: passo 2, imagem 3 %32
    • Unscrew the 4 screws holding the CPU heatsink and lift it up, gently.
    • Clean the old thermal paste both from the cooler and the CPU. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the CPU.
  3. HP EliteBook 845 G8 Thermal Paste Replacement, Applying new thermal paste.: passo 3, imagem 1 %32
    • Dont use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink.
    • Last, put the heatsink back carefully and tighten the screws in order 1 -> 4 to ensure even pressure.
  4. HP EliteBook 845 G8 Thermal Paste Replacement, Upgrading the RAM and SSD (Optional): passo 4, imagem 1 %32
    • Once you opened the back cover, it is a good idea to upgrade the RAM or the SSD if you want. Just carefully lift up the metal shields and replace them.
    • It is also recommended to use compressed air to remove any dust in the laptop and the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Simeon Brankov
Membro desde: 11/08/20
7.180 Reputação
Autoria de 54 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 37
Últimos 30 dias: 178
Ao todo: 2,881
