Ir para o conteúdo principal
HP EliteBook 8440p Keyboard Replacement
O que você precisa
  1. HP EliteBook 8440p Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 HP EliteBook 8440p Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 HP EliteBook 8440p Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Before you begin, unplug all cables and devices from the laptop.
    • Lay the laptop on its cover.
  2. HP EliteBook 8440p Keyboard Replacement: passo 2, imagem 1 %32 HP EliteBook 8440p Keyboard Replacement: passo 2, imagem 2 %32
    • Release the battery by pulling the battery tab to the left.
    • Remove the battery.
    • The battery is already removed in the reference image.
  3. HP EliteBook 8440p Keyboard Replacement: passo 3, imagem 1 %32 HP EliteBook 8440p Keyboard Replacement: passo 3, imagem 2 %32 HP EliteBook 8440p Keyboard Replacement: passo 3, imagem 3 %32
    • With a Phillips-head screwdriver, unscrew the three screws marked with the keyboard icon.
    • Do not remove the screws from the casing; they are built to stay in when loose.
  4. HP EliteBook 8440p Keyboard Replacement: passo 4, imagem 1 %32 HP EliteBook 8440p Keyboard Replacement: passo 4, imagem 2 %32 HP EliteBook 8440p Keyboard Replacement: passo 4, imagem 3 %32
    • Turn the laptop over and open the cover.
    • Push down the little clips located between the Function Keys to release the top of the keyboard. Lift the keyboard gently with a forward and upward motion.
    • Rest the keyboard over the touch pad.
    • When reassembling, line up the tabs at the keyboard's base with the casing's slots and reverse the motion.
  5. HP EliteBook 8440p Keyboard Replacement: passo 5, imagem 1 %32
    • Using a spudger or flat-head screwdriver, pull up the tabs at the black ribbon cable's sides to unlock the cable.
  6. HP EliteBook 8440p Keyboard Replacement: passo 6, imagem 1 %32 HP EliteBook 8440p Keyboard Replacement: passo 6, imagem 2 %32
    • Pull the black ribbon cable out of its slot.
  7. HP EliteBook 8440p Keyboard Replacement: passo 7, imagem 1 %32
    • Using a spudger or flat-head screwdriver, pull up the tabs at the white ribbon cable's sides to unlock the cable.
  8. HP EliteBook 8440p Keyboard Replacement: passo 8, imagem 1 %32 HP EliteBook 8440p Keyboard Replacement: passo 8, imagem 2 %32
    • Pull the white ribbon cable out of its slot.
  9. HP EliteBook 8440p Keyboard Replacement: passo 9, imagem 1 %32
    • Remove the keyboard from the laptop.
Conclusão
23 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 10-2, Green Fall 2015 Membro de Cal Poly, Team 10-2, Green Fall 2015
CPSU-GREEN-F15S10G2
3 Membros
Autoria de 3 guias
5Comentários do guia
The top of the keyboard has locking tabs that need to be pulled back towards the keyboard center or it won't come out. They hold the replacement keyboard in place long enough to get the screws into it.
Robert Taylor - Responder
But you don’t need to remove the battery.
Jakub Daszkiewicz - Responder
Taking it out was easy, putting a new one in- just impossible, brackets very brittle and cracking. Had to give it to the shop to fix it.
zbig j - Responder
Perfect guide except for keyboard tabs mentioned in comment from Robert Taylor! Well done!
Dave Tennant - Responder
PERFECT! It took me 15 minutes to replace the keyboard!
Victor Torkornoo - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 78
Ao todo: 18,124
