Ir para o conteúdo principal
HP EliteBook 840 G7 Wireless Card Replacement
O que você precisa
  1. HP EliteBook 840 G7 Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Wireless Card Replacement: passo 2, imagem 1 %32
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Wireless Card Replacement: passo 3, imagem 1 %32
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Wireless Card Replacement: passo 4, imagem 1 %32 HP EliteBook 840 G7 Wireless Card Replacement: passo 4, imagem 2 %32 HP EliteBook 840 G7 Wireless Card Replacement: passo 4, imagem 3 %32
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Wireless Card Replacement: passo 5, imagem 1 %32 HP EliteBook 840 G7 Wireless Card Replacement: passo 5, imagem 2 %32 HP EliteBook 840 G7 Wireless Card Replacement: passo 5, imagem 3 %32
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Wireless Card Replacement, Wireless Card: passo 6, imagem 1 %32
    • Detach both wires from the wireless card.
  7. HP EliteBook 840 G7 Wireless Card Replacement: passo 7, imagem 1 %32 HP EliteBook 840 G7 Wireless Card Replacement: passo 7, imagem 2 %32
    • Use a Phillips # 1 screwdriver, remove the one 2.5 mm screw securing the wireless card.
  8. HP EliteBook 840 G7 Wireless Card Replacement: passo 8, imagem 1 %32
    • Remove the wireless card
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 24
Duração total: 589
