Ir para o conteúdo principal
HP EliteBook 840 G7 Heatsink Replacement
O que você precisa
  1. HP EliteBook 840 G7 Heatsink Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop on its back.
  2. HP EliteBook 840 G7 Heatsink Replacement: passo 2, imagem 1 %32
    • Use the Phillips # 1 screwdriver to remove the five 1.2 mm screws from the back cover of the laptop.
  3. HP EliteBook 840 G7 Heatsink Replacement: passo 3, imagem 1 %32
    • Remove the back cover to expose the hardware.
  4. HP EliteBook 840 G7 Heatsink Replacement: passo 4, imagem 1 %32 HP EliteBook 840 G7 Heatsink Replacement: passo 4, imagem 2 %32 HP EliteBook 840 G7 Heatsink Replacement: passo 4, imagem 3 %32
    • Use your Phillips #1 screwdriver and remove the four 1.2 mm screws that secures the battery into place.
    • Remove the connector that connects the battery to the motherboard.
  5. HP EliteBook 840 G7 Heatsink Replacement: passo 5, imagem 1 %32 HP EliteBook 840 G7 Heatsink Replacement: passo 5, imagem 2 %32 HP EliteBook 840 G7 Heatsink Replacement: passo 5, imagem 3 %32
    • Lift up the battery with you hands or tools.
  6. HP EliteBook 840 G7 Heatsink Replacement, Heatsink: passo 6, imagem 1 %32 HP EliteBook 840 G7 Heatsink Replacement, Heatsink: passo 6, imagem 2 %32
    • Separate cables from heatsink and fan.
    • Unplug the fan power cable.
  7. HP EliteBook 840 G7 Heatsink Replacement: passo 7, imagem 1 %32 HP EliteBook 840 G7 Heatsink Replacement: passo 7, imagem 2 %32 HP EliteBook 840 G7 Heatsink Replacement: passo 7, imagem 3 %32
    • Use a Phillips # 1 screwdriver to remove the three 5mm screws from the fan housing.
    • Remove the fan from computer.
  8. HP EliteBook 840 G7 Heatsink Replacement: passo 8, imagem 1 %32 HP EliteBook 840 G7 Heatsink Replacement: passo 8, imagem 2 %32 HP EliteBook 840 G7 Heatsink Replacement: passo 8, imagem 3 %32
    • Use a Phillips # 1 screwdriver to remove the four 4mm screws from the heatsink.
    • Remove the heat sink from computer.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 30
Duração total: 552
