Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Whether you need to access the internal components of your HP Elitebook 840 G5 for further repairs, or you are just looking to replace the back plate of your laptop due to damage, please follow the step-by-step guide below to removing the back plate of your HP Elitebook 840 G5 safely and carefully. For reassembly, follow directions in reverse steps. The process required for many repairs or replacements on this product begin with the vital step of removing the back plate of the HP Elitebook 840 G5. Make sure to use extreme caution when completing this replacement; the internal electrical components of the laptop will be exposed!
O que você precisa
Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
Unscrew the bottom three screws using the same screwdriver.
To reassemble your device, follow these instructions in reverse order. This step is critical, as it is the beginning of all guides to access the internal of the computer.
6 outras pessoas executaram este guia.
2 comentários
Thank you so much for this tutorial! I was able to remove my bloated battery and replace it without taking the notebook into a repair shop. I ordered the screwdrivers on Amazon and my new battery and the screwdrivers arrived today. Job done! :)
