Introdução
Whether you need to access the internal components of your HP Elitebook 840 G5 for further repairs, or you are just looking to replace the back plate of your laptop due to damage, please follow the step-by-step guide below to removing the back plate of your HP Elitebook 840 G5 safely and carefully. For reassembly, follow directions in reverse steps. The process required for many repairs or replacements on this product begin with the vital step of removing the back plate of the HP Elitebook 840 G5. Make sure to use extreme caution when completing this replacement; the internal electrical components of the laptop will be exposed!
O que você precisa
Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
Unscrew the bottom three screws using the same screwdriver.
Turn computer so that the hinged side is facing up.
Use the plastic opening tool to pry open the back plate.
Drag the plastic opening tool along the edge from left to right and use a second opening tool to pry open the top right corner.
Repeat the 3rd step for the other side.
Repeat on Left and Right sides of the system. There are two points in the middle (on the left and right sides of the center screw) that will release with slight lifting pressure.
To reassemble your device, follow these instructions in reverse order. This step is critical, as it is the beginning of all guides to access the internal of the computer.
6 outras pessoas executaram este guia.
2 comentários
Thank you so much for this tutorial! I was able to remove my bloated battery and replace it without taking the notebook into a repair shop. I ordered the screwdrivers on Amazon and my new battery and the screwdrivers arrived today. Job done! :)
On my HP EliteBook 840 G5, the “two side screws” (black) are found inside the two holes seen next to the left top screw, and between the center and right top screw.
Ruedi Port - Responder
Mine had the same, and these black screws also need to be released in order to remove the bottom panel.
Josh -
Correct. Some other models have 2 black screws at the back, near the corners.
The models with the 2 black screws, are missing the 2 silver screws at the left side and the right side in the middle.
Note: You need to release the 2 black screws as well, if your type of model has them.
koppie007 - Responder
Thank you this was very helpful. I was able to remove the cover and the SSD.
Stupid question but is this board considered the hard drive? my laptop failed (no power) and I did get an identical replacement. In the past I have been able to remove the hard drive in the failed laptop and connect it to the new one via a data transfer cable (removed hard drive to usb in new laptop. I could then browse files off of the old hard drive and transfer them over to the new. This SSD board has vastly different connectors. Do you know if they make a transfer cable that connects to this board with a usb on the other end?
dgtuk1 - Responder
I removed the back cover and installed a new SSD. When I went to put the back cover, the center screw would not go back in. It turns but does not catch. Any advice?
Erik - Responder
