Introdução
Use this guide to replace your HP EliteBook 840 Aero G8 Wi-Fi Card. The Wi-Fi Card must be replaced when your PC stops connecting to Wi-Fi connection, or has slow, unreliable connection. Keep in mind to remove the battery as to avoid any injury from shock.
O que você precisa
Use a JIS #0 screwdriver to unscrew the three 6.73 mm case retention screws.
Use a JIS #0 screwdriver to unscrew and remove the two 8.76 mm screws.
Use the Halberd Spudger to remove the cable running along the bottom of the battery
Use the hook end of the halberd spudger to remove the black and white antenna cables connected to the Wi-Fi card
