Ir para o conteúdo principal
HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement
O que você precisa
  1. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Battery: passo 1, imagem 1 %32 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Battery: passo 1, imagem 2 %32
    • Use a JIS #0 screwdriver to unscrew the three 6.73 mm case retention screws.
    • Use a JIS #0 screwdriver to unscrew and remove the two 8.76 mm screws.
  2. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 2, imagem 1 %32 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Halberd Spudger
    $2.99
    Comprar
    • Use the Halberd Spudger to remove the cable running along the bottom of the battery
  3. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 3, imagem 1 %32 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 3, imagem 2 %32
    • Disconnect the cable connected the battery to the motherboard
  4. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 4, imagem 1 %32 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 4, imagem 2 %32
    • Use a JIS #0 screwdriver to unscrew the four 7 mm screws that secure the battery.
  5. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 5, imagem 1 %32
    • Slide the battery out of the clips to remove it from the laptop.
  6. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Heat Sink and Fan: passo 6, imagem 1 %32 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement, Heat Sink and Fan: passo 6, imagem 2 %32
    • Unplug the fan cable from the motherboard.
  7. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 7, imagem 1 %32 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 7, imagem 2 %32
    • Use the JIS #0 screwdriver to remove the three 5.33 mm screws that secure the fan.
  8. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 8, imagem 1 %32 HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 8, imagem 2 %32
    • Use a JIS #0 screwdriver to remove the four 4.06 mm screws from the heat sink.
  9. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 9, imagem 1 %32
    • Lift the fan free.
  10. HP EliteBook 840 Aero G8 Heat Sink and Fan Replacement: passo 10, imagem 1 %32
    • Lift the heat sink free.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 798
