Ir para o conteúdo principal
HP EliteBook 830 G5 Battery Replacement
O que você precisa
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer
    • Disconnect all external devices from the computer.
  1. HP EliteBook 830 G5 Battery Replacement, Remove the bottom cover: passo 2, imagem 1 %32 HP EliteBook 830 G5 Battery Replacement, Remove the bottom cover: passo 2, imagem 2 %32
    • Turn the computer upside down on a flat surface.
    • Loosen the five captive screws.
    • Loosen the two inset captive screws.
    • Starting under the display, insert a case removal tool and lift the bottom cover of the computer.
  2. HP EliteBook 830 G5 Battery Replacement, Remove the battery: passo 3, imagem 1 %32 HP EliteBook 830 G5 Battery Replacement, Remove the battery: passo 3, imagem 2 %32
    • Disconnect the battery cable from the system board.
    • Remove the five Torx T8 2.5×4.0 screws.
    • Rotate the top of the battery upward, and then lift the battery out of the computer.
Conclusão
To replace the battery & reassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Max Kletskov
Membro desde: 04/22/20
40.307 Reputação
Autoria de 16 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 26
Últimos 30 dias: 99
Duração total: 2,369
