Ir para o conteúdo principal
HP EliteBook 745 G4 Battery Replacement
O que você precisa
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: passo 2, imagem 1 %32
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: passo 3, imagem 1 %32 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: passo 3, imagem 2 %32
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: passo 4, imagem 1 %32
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: passo 5, imagem 1 %32
    • Loosen the two captive screws and remove the battery from the computer
Conclusão
To replace the battery & reassemble your device, follow these instructions in reverse order.
3 outras pessoas executaram este guia.
Max Kletskov
Membro desde: 04/22/20
40.418 Reputação
Autoria de 16 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.103 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 43
Duração total: 1,298
