Ir para o conteúdo principal
HP EliteBook 745 G2 Battery Replacement
O que você precisa
  1. HP EliteBook 745 G2 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Gently place the laptop down on a suitable workplace with the back of the laptop facing up
  2. HP EliteBook 745 G2 Battery Replacement: passo 2, imagem 1 %32 HP EliteBook 745 G2 Battery Replacement: passo 2, imagem 2 %32
    • Remove the cover by sliding the lock to the left. You will hear a click once the cover has been unlocked. Gently push down on the cover and slide it towards you to remove it.
  3. HP EliteBook 745 G2 Battery Replacement: passo 3, imagem 1 %32 HP EliteBook 745 G2 Battery Replacement: passo 3, imagem 2 %32
    • Gently lift up on the battery (represented by this cardboard cutout) until it disconnects. Once the battery is disconnected lift away from laptop.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 1,018
