Ir para o conteúdo principal
HP EliteBook 1040 G4 Trackpad Replacement
O que você precisa
  1. HP EliteBook 1040 G4 Trackpad Replacement, Back Cover: passo 1, imagem 1 %32
    • Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
  2. HP EliteBook 1040 G4 Trackpad Replacement: passo 2, imagem 1 %32 HP EliteBook 1040 G4 Trackpad Replacement: passo 2, imagem 2 %32
    • Lift the back cover up and off the device.
  3. HP EliteBook 1040 G4 Trackpad Replacement, Battery: passo 3, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
  4. HP EliteBook 1040 G4 Trackpad Replacement: passo 4, imagem 1 %32 HP EliteBook 1040 G4 Trackpad Replacement: passo 4, imagem 2 %32
    • Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
  5. HP EliteBook 1040 G4 Trackpad Replacement: passo 5, imagem 1 %32 HP EliteBook 1040 G4 Trackpad Replacement: passo 5, imagem 2 %32
    • Lift and remove the battery from the device.
  6. HP EliteBook 1040 G4 Trackpad Replacement, Trackpad: passo 6, imagem 1 %32
    • Peel back the foam cover to reveal the underside of the trackpad.
  7. HP EliteBook 1040 G4 Trackpad Replacement: passo 7, imagem 1 %32
    • Carefully disconnect the white ribbon cable attached to the underside of the trackpad.
  8. HP EliteBook 1040 G4 Trackpad Replacement: passo 8, imagem 1 %32
    • Carefully disconnect the black ribbon cable attached to the chassis.
  9. HP EliteBook 1040 G4 Trackpad Replacement: passo 9, imagem 1 %32
    • Use a Phillips #00 screwdriver to remove the six 2 mm screws securing the trackpad.
  10. HP EliteBook 1040 G4 Trackpad Replacement: passo 10, imagem 1 %32
    • Lift and remove the trackpad from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 312
