Introdução
Use this guide to replace the Motherboard on the HP Elitebook 1040 G4. The Motherboard is the backbone that ties all components of the computer together. It moves power throughout the device and provides a central place for communication. If you are noticing problems with your computers speed, graphics, or hardware, you may need to replace your motherboard.
To complete this guide, you will need a #T5 Torx head screwdriver and a Phillips #0 and #00 screwdriver.
Before beginning, be sure to completely power off your computer.
O que você precisa
Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
Using the Phillips #00 screwdriver, remove the single 5 mm screw securing the SSD to the motherboard.
Using the Phillips #0 screwdriver, remove the two silver 5 mm screws surrounding the fan.
Using the Phillips #0 screwdriver, remove the five black 4 mm screws securing the motherboard to the device.
Remove the ZIF connector from the bottom left of the motherboard by lifting the small grey tab, then pulling the connector out of the slot.
For more information on properly disconnecting and removing Zero Insertion Force (ZIF) connectors, please visit this guide.
