Ir para o conteúdo principal
HP Elite x2 G4 Battery Replacement
O que você precisa
  1. HP Elite x2 G4 Battery Replacement, Display Assembly: passo 1, imagem 1 %32
    • Open the kickstand.
    • Remove the four 3 mm T5 Torx-head screws that secure the display assembly.
  2. HP Elite x2 G4 Battery Replacement: passo 2, imagem 1 %32
    • Use a suction sup to carefully detach the display assembly in the following order: top-right corner, top-left corner, bottom-right corner and bottom-left corner.
  3. HP Elite x2 G4 Battery Replacement: passo 3, imagem 1 %32
    • Slowly lift the display panel until you have access to the battery connector on the motherboard (approx. 90 degrees).
  4. HP Elite x2 G4 Battery Replacement: passo 4, imagem 1 %32
    • Disconnect the battery cable from its motherboard connector.
    • Remove the tape that covers the touchscreen and display panel ZIF connectors.
  5. HP Elite x2 G4 Battery Replacement: passo 5, imagem 1 %32
    • Disconnect the touchscreen ribbon cable from the motherboard.
    • Remove the display panel assembly.
  6. HP Elite x2 G4 Battery Replacement, Battery: passo 6, imagem 1 %32
    • Remove the six 3.5 mm Phillips #1 screws that secure the battery to the display enclosure.
  7. HP Elite x2 G4 Battery Replacement: passo 7, imagem 1 %32
    • Carefully lift the top edge of the battery off of the alignment pins.
    • Remove the battery.
  8. HP Elite x2 G4 Battery Replacement: passo 8, imagem 1 %32
    • Slide the bottom edge out from retention tabs on the display enclosure and remove.
Conclusão
Uma outra pessoa concluiu este guia.
Goncalo Felix
Membro desde: 10/25/22
325 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-4, Sinclaire Fall 2022 Membro de UMass Dartmouth, Team 4-4, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G4
Membros da 5
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 99
Duração total: 1,380
