Ir para o conteúdo principal
HP Elite x2 G1 1012 Display Replacement
O que você precisa
  1. HP Elite x2 G1 1012 Display Replacement, Display: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • With the screen face down, lift up the stand as far as it goes.
    • Make sure not to force it past the resting point.
  2. HP Elite x2 G1 1012 Display Replacement: passo 2, imagem 1 %32 HP Elite x2 G1 1012 Display Replacement: passo 2, imagem 2 %32
    • Use a T5 driver to remove the six screws on the back of the tablet.
  3. HP Elite x2 G1 1012 Display Replacement: passo 3, imagem 1 %32
    • After removing the screws, delicately close the stand.
    • Flip the tablet on its back so that the screen is facing up.
  4. HP Elite x2 G1 1012 Display Replacement: passo 4, imagem 1 %32 HP Elite x2 G1 1012 Display Replacement: passo 4, imagem 2 %32
    • Use the suction cup to carefully separate the screen from the device. Pull upwards with a fluid and smooth motion.
    • Do not lift too fast! There will still be wires connecting the screen to the device. Make sure they are not tampered with.
  5. HP Elite x2 G1 1012 Display Replacement: passo 5, imagem 1 %32 HP Elite x2 G1 1012 Display Replacement: passo 5, imagem 2 %32 HP Elite x2 G1 1012 Display Replacement: passo 5, imagem 3 %32
    • Remove the tape on the lower left side of the screen.
    • Underneath the tape, disconnect the LCM cable, the larger wire that was underneath the tape, from the back of the tablet screen.
  6. HP Elite x2 G1 1012 Display Replacement: passo 6, imagem 1 %32 HP Elite x2 G1 1012 Display Replacement: passo 6, imagem 2 %32
    • Disconnect the flex cable from the device using the spudger.
    • Remove the Display Assembly from the device.
Conclusão
4 outras pessoas executaram este guia.
Colin Mika
Membro desde: 04/19/18
943 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team S24-G7, Maness Spring 2018 Membro de Cal Poly, Team S24-G7, Maness Spring 2018
CPSU-MANESS-S18S24G7
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 32
Duração total: 3,335
