Ir para o conteúdo principal
HP Elite x2 1012 G2 Speakers Replacement
O que você precisa
  1. HP Elite x2 1012 G2 Speakers Replacement, Screen: passo 1, imagem 1 %32
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Speakers Replacement: passo 2, imagem 1 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 2, imagem 2 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 2, imagem 3 %32
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Speakers Replacement: passo 3, imagem 1 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 3, imagem 2 %32
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Speakers Replacement: passo 4, imagem 1 %32
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Speakers Replacement: passo 5, imagem 1 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 5, imagem 2 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 5, imagem 3 %32
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Speakers Replacement: passo 6, imagem 1 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 6, imagem 2 %32
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Speakers Replacement, Speakers: passo 7, imagem 1 %32
    • Identify the speaker locations.
  8. HP Elite x2 1012 G2 Speakers Replacement: passo 8, imagem 1 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 8, imagem 2 %32
    • Remove the antennae connections from both the WiFi card and the wireless cellular M.2 card.
    • Gently pull the black and red wire free at the motherboard connector.
  9. HP Elite x2 1012 G2 Speakers Replacement: passo 9, imagem 1 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 9, imagem 2 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 9, imagem 3 %32
    • Use the spudger tool to remove the speakers from the housing.
  10. HP Elite x2 1012 G2 Speakers Replacement: passo 10, imagem 1 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 10, imagem 2 %32
    • On the right speaker, the black antena piece must be removed before the speaker can be accessed.
  11. HP Elite x2 1012 G2 Speakers Replacement: passo 11, imagem 1 %32 HP Elite x2 1012 G2 Speakers Replacement: passo 11, imagem 2 %32
    • Now remove the green and white wires from the cable management track and the speakers will be completely removed from the device.
Conclusão
Uma outra pessoa concluiu este guia.
WesleyEagleson
Membro desde: 04/06/19
431 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S13-G13, Wilson Spring 2019 Membro de IUPUI, Team S13-G13, Wilson Spring 2019
IUPUI-WILSON-S19S13G13
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 43
Duração total: 1,286
