Ir para o conteúdo principal
HP Elite x2 1012 G2 Rear Facing Camera Replacement
O que você precisa
  1. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Screen: passo 1, imagem 1 %32
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 2, imagem 1 %32 HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 2, imagem 2 %32 HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 2, imagem 3 %32
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 3, imagem 1 %32 HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 3, imagem 2 %32
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
    • During reassembly, certain clips/edges may not snap into place properly even with a lot of force. To counteract this, lift the edge up, place the suction cup further inwards on the screen and pull it slightly upwards while pressing the edge of the screen downwards. The edge should snap correctly into the housing.
  4. HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 4, imagem 1 %32
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 5, imagem 1 %32 HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 5, imagem 2 %32 HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 5, imagem 3 %32
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 6, imagem 1 %32 HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 6, imagem 2 %32
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: passo 7, imagem 1 %32 HP Elite x2 1012 G2 Rear Facing Camera Replacement, Rear Facing Camera: passo 7, imagem 2 %32
    • Locate the cameras at the top center of the power and processing unit.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw.
    • Use a spudger tool to lift up the ribbon cable clamps.
    • Be careful not to crease or damage the ribbon cables or connectors.
  8. HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 8, imagem 1 %32 HP Elite x2 1012 G2 Rear Facing Camera Replacement: passo 8, imagem 2 %32
    • Remove the front-facing camera.
    • Remove the metal bracket securing the rear-facing camera.
    • Remove the rear-facing camera.
Conclusão
WesleyEagleson
Membro desde: 04/06/19
431 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S13-G13, Wilson Spring 2019 Membro de IUPUI, Team S13-G13, Wilson Spring 2019
IUPUI-WILSON-S19S13G13
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 9
Ao todo: 599
