Ir para o conteúdo principal
HP Elite x2 1012 G2 Battery Replacement
O que você precisa
  1. HP Elite x2 1012 G2 Battery Replacement, Screen: passo 1, imagem 1 %32
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Battery Replacement: passo 2, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 2, imagem 2 %32 HP Elite x2 1012 G2 Battery Replacement: passo 2, imagem 3 %32
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Battery Replacement: passo 3, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 3, imagem 2 %32
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
  4. HP Elite x2 1012 G2 Battery Replacement: passo 4, imagem 1 %32
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Battery Replacement: passo 5, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 5, imagem 2 %32 HP Elite x2 1012 G2 Battery Replacement: passo 5, imagem 3 %32
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Battery Replacement: passo 6, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 6, imagem 2 %32
    • Remove the screen by gently lifting it off of the device.
  7. HP Elite x2 1012 G2 Battery Replacement, Battery: passo 7, imagem 1 %32
    • Orient the device so that the battery is closest to you.
    • The battery is the large, black rectangle at the bottom of the device.
  8. HP Elite x2 1012 G2 Battery Replacement: passo 8, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 8, imagem 2 %32
    • Remove all six Phillips 3 mm screws around the battery by rotating in the counterclockwise direction with a Phillips screwdriver.
  9. HP Elite x2 1012 G2 Battery Replacement: passo 9, imagem 1 %32 HP Elite x2 1012 G2 Battery Replacement: passo 9, imagem 2 %32
    • Remove the battery's connector by pushing both sides of the tab towards yourself with a plastic opening tool.
  10. HP Elite x2 1012 G2 Battery Replacement: passo 10, imagem 1 %32
    • Lift the battery out of the device.
Conclusão
13 outras pessoas executaram este guia.
Andy Velazquez
Membro desde: 04/18/18
314 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S18-G5, Livingston Spring 2018 Membro de Cal Poly, Team S18-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G5
Membros da 4
Autoria de 13 guias
4 comentários
how do you test the battery? what voltage should it be maintaining?
scott kay - Responder
Hi, after the replacement battery
toch not working, help pls?
Parsa Aghabeikzadeh - Responder
PC not coming on, also not charging.
Abiola - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 84
Últimos 30 dias: 403
Duração total: 22,009
